2 Attachment(s)
UCSB 0-10v spindle control
I was hoping someone could point me in the right direction.
I am struggling to connect the PWM output on my UCSB breakout board to a PWM to 0-10V converter (attached images) to control the speed of my VFD (H100).
The converter I am using requires a GND (-) and PWM (+) as input. As I understand it, the converter requires the PWM signal to be positive. But the UCSB board signals seem to be switching ground, so the PWM signal coming from the board is negative.
Is there a way to connect these two? Can I use a pull-up resistor to get a positive PWM pulse from the UCSB?
Link to UCSB: https://cncdrive.com/UCSB.html
Any help/suggestions would be appreciated.
