C Axis calibrating (for aggregates)
Greetings,
I have a 4 axis machine wherein, a motorized "C Axis" rotates my aggregates around the Z axis so I can cut with a saw aggregate along X or Y or anywhere in between. It's an HSD unit, "Axis MK250" to be exact. Rotating it to 0 (of 360) is part of the home operation.
I had reason to believe that it was not properly calibrated because my saw kerf measured 4.5mm rather than 3.2 mm which is the actual saw kerf spec. When I used dial indicators to determine if it was off I found that the C is about 1.3 deg from 0 on two different Aggregates.
My question is; does anyone know how to adjust the "C axis sensor" that tells it when to stop rotating at 0 when it's homing? Or even where it's located? Alternatively, how can I do it through the software so that this 1.3 degrees is compensated?
Re: C Axis calibrating (for aggregates)
Quote:
Originally Posted by
Heirloomwindows
Greetings,
What is your CNC controller brand and model name?
Have you tried to go back to the reference point (return home operation) ?
The controler is LNC 2000 I think. The machine is a Style CNC
Yes, even after Homing, the C axis is off 1.3 degrees. This is true with a Saw aggregate. I know this because when I saw at 0 the kerf is 4.5mm or so. When I saw at -1.3 degrees (88.7) the kerf is 3.4 (supposed to be 3.2mm) and increasing or decreasing the deflection only increases the kerf. I measured another 90 degree tool and it reads at least 1 deg off.
