Easy multiple part method like G98 for sheetmetal??
Hi Rodney,
In programming parts for Amada CNC Turret punches there is a G98 code which allows you to create multiple parts in both the X and Y axis from a single part and the use of macros. I wanted to know if there is such an option with Dolphin Partmaster for doing multiple parts? It would just be less work to create the part one time with offsets from the edge and then just define the number in the X and Y axis with the distance in between each row. This kind of a program is very easy to change for a different material blank size at any time also. I have some small parts to mill and this would be faster than drawing multiples and probably make a smaller program too. Also what is the status of the posts for Amada? Thanks!
