HELP WITH VERTICAL CENTER BRIDGEPORT BPC-250V, FANUC 11M, 1986 MACHINNE
Hello, as are all?
I have a vertical center Bridgeport PCB-250V with Fanuc control 11M. dated 1986
I introduced the following judgement.
When running a program from the peripheral (lapte op) all axes are moved according to the lines read, gives me a work stoppage when the runs the G43 line of code, stopping the team without being able to resume reset, it can only continue to operate when the machine shut down completely. The display does not present any parameters of error.
The electrical connection is through a phase converter Des co-new 20 hp.
Previously implemented programmes successfully.
