Problems with Busy Bee Lathe.
I bought a CT089 13x24 lathe less than a week ago and upon unloading/ uncrating it I noticed that the tool post cross slide had been run into the chuck…that’s the first problem. After unloading it and cleaning it up I started the break in process... 15-20 minutes in each gear setting. The problem is when I try to start it in any gear higher than 600 rpm the motor just pulses and doesn’t get up to running speed. I cleaned out all the junk oil it came with and replaced it with ISO AW32, stuck a magnetic block heater on it (my shop is around 10-15c) and it still won’t go over 600 rpm… actually it did once but than it tripped the 20amp breaker after running for only 2 minutes.
I phoned the store I bought it from and they told me to talk to the central office. Over a few phone conversations the tech at the central office told me to:
Keep breaking it in in the lower gears.
Check pulley alignment and belt tension… its fine.
Change the oil… I did that already.
Make sure the bearings aren’t running hot… barely warm
Disengage the lead screw gear so only the spindle is being driven.
Take the chuck off… less rotating weight.
Check the run capacitor… wasn’t able to give me any specs to look for (ohms).
I did all these and it still has all the same problems. I asked him about the chuck grooves in the cross slide and he agreed that it most likely happened at the factory because the nylon gear would have broken and the worker most likely just replaced the gear because he didn’t want to get into trouble.
Now it looks like my only option, as far as the tech has told me, is to borrow a pickup truck and engine hoist again, and drop it off at there central office. Let them have a look at it and either go back and pick up my repaired lathe or a new one. For a total of 4hrs of driving.
If anybody has any advice on anything else I could try or check before bringing it back I would appreciate it. As far as my advice for others before you fork over your hard earned cash for a tool from Busy Bee, make sure you thoroughly visually and mechanically inspect it. I wish I would have done that and maybe I would have saved myself a lot of frustration.
Re: Problems with Busy Bee Lathe.
Quote:
Originally Posted by
383IROC
Hi I have the same lathe. There is no mention of breaking it in, in the manual. Although that sounds reasonable as all the gears are new.
Where did you find this oil spec? and where is the break-in procedure? Ours is quite new but we never thought to do that.
I am turning something oversize 11" Iron casting and my Gear selector (red black dot one) is popping out of gear. It is on a low gear. But it is annoying. It just slips into neutral if there is too much resistance.
I am not taking off too much .005" cut with carbide.
I would like to know more about the break-in procedure. I think I should be doing that. and why is it not in the manual with the oil spec.???
Thanks Rick M
