Broke the connection for my chuck clamp/unclamp foot pedal.. how to I clamp unclamp w/o? I can unclamp in MDI with M11 however when I then try to chuck with M11 it errors that the chuck is unclamped... Need to resume production asap!
Printable View
Interesting problem. I wonder if you can trick the machine by switching to ID chucking then program in to open the jaws followed by m0 so you'll have time to close the door. You'll also have to override the door safety switch.
hmmm... ill try... how do you switch to id chucking?
It is possible to do this if you change the parameter setting CHUCK OPEN CS to 1 it will allow you to open the chuck in MDI when it is closed all though I would only use the as a last resort because the spindel will also run with out the chuck clamped and this could be bad!!! I would not let an operator do this but to finish out a job or part I may do it my self I not sure if it will affect anything else so be very careful.
found the id chuck setting.. thanks! i will try to change the parameter as well and see how that goes! thanks for your help!
Seems like it shouldn't be too hard to repair the broken connection.
We didn't use ID chucking very often but I think it's under Settings.
well, no, it shouldnt be that hard to fix it.... it did break the plastic tho. I just wanted to cut open the back of the connection box, extend the leads, and plug those into the pedal... But boss says we should just order a new one.. haha whatever
CHUCKER:
How do I unlock the abillity to change params? says FUNCTION LOCKED when I try to adjust it....
I haven't run the Haas in a while that's why I'm not 100% certain but I think you have to change a Setting before you can change the Parameters.
go to the setting page and turn on setting 7 this will unlock it for you it may say servo is on if so just push estop then try to change it again
