Real World Load Test, Help.
So I've got my BP clone CNC retrofit up and running on the X and Y. I'm getting about .0005" backlash from my cheap angular bearings, which is solved perfectly by Mach backlash comp.
The question is, is there a real world load test to see if the backlash exaserbates as it is milling something like steel? I mean the table pulls me without loosing steps or position but that's once the backlash is taken up and the balls in the nut are already against that side of the nut so putting weight on table as it moves doesn't tell me much. I'm just wondering if backlash will stay the same. I think it will.
I know not the right forum for the next question but most of you guys know about mach. I enabled backlash comp in mach, do I need to change the number of lines for the look ahead? Currently it's at 20.
