Quote:
I/O Points
Point
Usage
Spindle Power
(Output) Drives relay that turns spindle motor on and off. Could also drive spindle brake.
Spindle Direction
(Output) Drives relay that sets spindle direction to clockwise or counter clockwise.
Coolant A
(Output) Drives relay that controls flood coolant pump
Coolant B
(Output) Drives relay that controls mist coolant pump
PLC Handshake Signal
(Output) Signal controlled by M70 and M71 to provide programmatic interface to a Programmable Logic Controller or other electronics
Drive Enable 1
(Output) Used to enable or disable one or more motor drives. Since some motor drives require individual enable lines, TurboCNC provides three independent lines which are controlled by the same M17/M18
Drive Enable 2
Drive Enable 3
Clamp Selector Bit 0
(Output) – used with Bits 1, 2, 3 to specify which clamp is to be controlled.
Clamp Selector Bit 1
(Output) – used with Bits 0, 2, 3 to specify which clamp is to be controlled.
Clamp Selector Bit 2
(Output) – used with Bits 0, 1, 3 to specify which clamp is to be controlled.
Clamp Selector Bit 3
(Output) – used with Bits 0, 1, 2 to specify which clamp is to be controlled.
Clamp Motor On Signal
(Output) drives clamp controller specified by Clamp Selector Bits 0-3.
Clamp Direction Closed
(Output)
Tool Turret Index
(Output) Toggles 1 times the tool number of pulses when an M06 instruction is executed.
Collet Open Solenoid
(Output) drives mechanism to open the tool holder, which may be a collet
Collet Close Solenoid
(Output) drives mechanism to close the tool holder, which may be a collet
Emergency Stop
(Input) when activated, this line causes the CNC machine to stop operation.
Limit Switch 1
(Input) Is activated when Axis #1 reaches either limit of its travel.
Limit Switch 2
(Input) Is activated when Axis #2 reaches either limit of its travel
Limit Switch 3
(Input) is activated when Axis #3 reaches either limit of its travel
PLC Handshake Sense
(Input) Used to synchronize the CNC machine to a Programmable Logic Controller or other electronic device.
Spindle Index
(Input) Used to synchronize lathe’s lead screw to spindle for gearless thread cutting. Can also be used to calculate and display spindle speed.
Spindle Encoder A
(Input) Not currently used
Spindle Encoder B
Touch Probe
(Input) Stops motion on a G31/32 or probe move in jog mode. Often used for digitizing part data or toolsetting.
Jog Encoder A
(Input) Quadrature channel A of a jogging encoder wheel. In discrete jog mode, this is an input to move an axis.
Jog Encoder B
(Input) Quadrature channel B of a jogging encoder wheel. In discrete jog mode, this is an input to move an axis.
Block Hold
(Input) When active, TurboCNC will not execute the next block in the CNC program. Could be used as a single step control.
Start Inhibit
(Input) When active, TurboCNC will not start executing a CNC program. Could be used to allow a raw materials handler to remove completed part from machine and insert new raw material.
Clamp Sense Opened
(Input) line which is activated when the clamp specified by the Clamp Select bits is opened
Clamp Sense Closed
(Input) line which is activated when the clamp specified by the Clamp Select bits is closed
Home Switch 1
(Input) Senses when Axis #1 is at home position
Home Switch 2
(Input) Senses when Axis #2 is at home position
Home Switch 3
(Input) Senses when Axis #3 is at home position
Home Switch 4
(Input) Senses when Axis #4 is at home position
Home Switch 5
(Input) Senses when Axis #5 is at home position
Home Switch 6
(Input) Senses when Axis #6 is at home position
Home Switch 7
(Input) Senses when Axis #7 is at home position
Home Switch 8
(Input) Senses when Axis #8 is at home position
cheers,
