Tree J325- First time start up-Help
I am new to the Tree J325 with a Dynopath Delta 20. I just powered up the machine and have the following in the fault status. Please walk me through clearing the faults so I can reset the machine and move on to the next challenge
Fault:
-Emergency Stop
-Enter reset to continue
-Air pressure low
-Z axis over travel
I don’t have the air hooked up yet, what pressure should I set the regulator? I have reset the Emergency stop on the control and it seems to be working properly.
still working on the Z axis over travel
I have the air hooked up and have cleared that error.
I still have the following:
-Emergency Stop
-Z axis over travel
I retracted the quill up (it was down about ½”) to where the zero reference should be at the bottom of the chrome plate, hit reset and still have the error.
I took off the inspection plate and I can see that the e-stop for the quill is making contact. At least I believe that it is an e-stop I am looking at. It has a bolt that travels between to contacts as the quill moves up and down. With the quill at zero as I mentioned above, ½ of the screw is making contact with the top stop.
I rolled the quill on and off of the contact and tried hitting reset again. I still can not clear the Z axis over travel error.
I can not jog anything on the machine. I assume that I will not be able to until I clear all the error messages. Is this correct?
