3 Attachment(s)
Another DIY drum sander build
This 24" drum sander is based on the Stockroom Supply info on their web site, and will have modifications as needed to make it work with parts and materials that I already have on hand.
The basic structure was cut from 3/4" B-C grade plywood and assembled with Titebond II and deck screws today.
The 3/4" ID bearing blocks have a mounting base that is wider than 3/4" so I added a 3/4" plywood doubler plate to the outside at each end of the structure for them to sit on. Threaded inserts will be installed into the structure for mounting the bearing blocks.
The motor mounting plate will be hinged so that the weight of the motor keeps tension on the link belt. The old Delco "RigidFrame" cast iron 1/4 hp 1725 rpm runs so quiet it can hardly be heard. This motor is under powered for using the full drum width but it should work ok for my uses. I don't plan to use full drum width very often, if at all. If I happen to run across a free 1/2 hp motor I'll change it out.
i have a piece of 1018 cold rolled steel bar stock that will be used for the drum axle. It will need to be turned smaller on the pulley end for a 1/2" ID pulley. Flats will be put on the axle where set screws are located.
I intend to make a drum from 3" galvanized steel pipe that will be surface turned on the lathe, and balanced for minimal vibration. Galvanized pipe has a welded seam that may cause the pipe to be a little heavier on that side of the pipe. Probably enough to cause vibrations. Steel end caps will be welded into the pipe. The axle will go all the way through the pipe and end caps. A spacer ring will be located in the center of the pipe and held in place with three countersunk flat head socket screws that will get radiused while truing the surface in the lathe. The screws will have red thread locker on them.
The table top will be made of 3/4" B-C grade plywood, with red oak framing to help keep it flat. Formica will be applied to the top surface.
This project will not be fast paced. It will be mixed in with my CNC router build and a non-CNC DIY open back banjo build as I feel like working on it and have the parts to continue building it.
CarveOne
