Re: open source Atmel/arduino PID motor control
How is work? Look good.
Sent from my LT18i using Tapatalk
Can you give me some information about RPM sensor? Your link you give here is inaccessible. Thanks!
Hi friends I want to do this project. But could not figure out how you can help the CON11 connentor work?
Quote:
Originally Posted by
recep89
You need to provide, say a 3V to 5V positive going pulse to con11.pins 1 & 2 This pulse will trigger the triac to turn it ON.
KOC62
Does the need to give 5V connector CON11 ?
GT-I9300 cihazımdan Tapatalk kullanılarak gönderildi
recep89
For example, if you use an Arduino, it will provide the pulse to CON11. You don't apply 5V to the CON11.
KOC62
I got it , thank you for the information you gave on
excuse my ignorance...in the end what should be connected to CON 11 ? and the sensor is connected to the J - HLS - 1 ?
acilin1
CON 11:
Needs a pulse to fire the triac. This pulse comes from the Arduino controller.
J-HLS-1:
Needs a pulse from the sensor to indicate that the motor rotated 360 degrees. 1 pulse for every motor shaft revolution.
excuse me but do not understand...That means do not connect anything to con 11 connections are already on the pcb? must put a switch? ...
acilin1
No.
Connectors are used to connect something from another device. In this case, it means that your speed sensor connects to J-HLS-1 so that the Arduino can calculate at what RPM the motor is turning.
yes to con j-hls-1 i connecting the rpm sensor but to con 11 What should I connect?
acilin1
I didn't look at the pcb. Taking another look at the schematic it looks he uses D5 port from the Arduino to provide the trigger for the triac.
If this connection is already on the pcb then you don't need to connect anything to this connector. It would be a method to connect an other trigger source than the Arduino.
I never finished building this project, and I don't have a pcb either.
Sorry if I confused you with my previous comments. I didn't notice the D5 line before, which I assume is on the pcb.
someone can tell me what voltage have the capacitors in the original scheme?
