Not to burst any bubbles but. . .
Graham's law covers effusion not diffusion. Effusion is where gases of different molecular weights flow through a small holes at different rates. Diffusion is the process by which gases with different concentrations on opposite sides of a semi-permeable membrane travel opposite the concentration gradient to reach equilibrium.
Diffusion is the the process by which a vacuum chamber will come to equilibrium with its contents due to the fact that there is vacuum in the chamber and trapped air in the part. The rate of diffusion is proportional to the concentration difference on the two sides.
Effusion is what would happen if you put a bottle of helium at atmospheric pressure in a chamber and placed a pinhole in the bottle and watched the helium atoms slowly leave through the hole and enter the chamber.
Helium is of interest here because it is capable of escaping through tiny holes that other substances are not. This is why it is used to test high vacuum systems for leaks. Hydrogen is even better at escaping through tiny holes but also flammable and can effect the chemistry of some things like metals.
Walter,
My condolences on the X2 column assembly. It looks like you had a lot going for you but that it just went wrong! I suppose this says that jigs to hold everything in place are going to be critical. The other thing is that judging by the place where the foam showed through, it looks like the intended E/G section was not thick enough.
It was definitely a brave step to make that part and I am sure that there are lessons we can all learn from it. I think the first lesson I'd take is to try to make castings as simple as possible. You are the Edison of Epoxy Granite right now and you just found the first of "a thousand things that did not work".
Despite the failure, it's a great service to the community that you did this and I want to congratulate you for trying such that we may all learn from this experiment.
--Cameron
