I have to say that I am a bit disappointed in the performance of the 2.2Kw spindle. I've calculated all the loads at less than one horsepower, and it bogged down and tripped the inverter a couple times. It has also already developed some end play, and it sounds almost like the bearings are dry or nearly dry. I need to take it apart and check it out soon. I'm not sure HOW to take it apart though. The back cap opens the water passages and exposes the electrical wires going into the motor from the connector. (There was no frame ground as I expected so I connected one.) There is an oval shaped bolt head with two flats on the back end of the shaft. If I need to grip that I'll probably have to make a socket to do the job. There is what looks like a threaded lock ring on the front end of the shaft with pin wrench holes on the face. Its made of aluminum so the usual short cut of tapping it with a punch and a hammer probably isn't a good idea. I'll probably have to make a pin wrench for it unless one of my angle grinder pin wrenches just happens to fit.
