A QUICK REVIEW, FOR THOSE JUST JOINING US! :stickpoke (group)
www.cncbridges.com - famous X2 Mini Mill, polymer concrete Base.
www.moglice.com - Castable Bearing and Machine Tool Repair Resin.
www.itwpolymercastings.com - Zanite, magic polymer composite!
www.accurescasting.com - "3 cu ft Filler kit for 360$ (435 lbs) -epoxy included"- message#10.
www.sika.com - Rapid High Strength Pourable Epoxy Grout - Grouting of bearing plates, machine bases, mechanical bridge joints, bridge bearings and rail base plates- message#12.
www.precisionepoxy.com - Awesome Epoxy Surface Plate! - DIY Instructions.
http://www.machinedesign.com/asp/vie...MDSite&catId=2 - "Machine Design" article on Polymer Castings, pics!
www.epoxysystems.com - Most Confusing Epoxy Site Ever.(flame2)
www.shopmaninc.com - "Low viscosity epoxy like 30 bucks a gallon" - thanks Larry!:D :D :D
http://www.pavepatch.com/flexset-rap...5gal-p-29.html
member The4thseal paving his way to perfect machine frame- message#45
www.reade.com - Specialty Aggregates (filler).
www.kafkagranite.com - Specialty Aggregates, Landscape Products.
http://www.watco.co.uk/asp/autopage....CXDF&Group=REP - "ready-to-use mixed epoxy-concrete?"
http://www.reichhold.com/composites/.../app.cfm?ID=91 - polymer concrete resin.
http://www.mech.utah.edu/~bamberg/re...e%20Design.pdf - "Principles of Rapid Machine Design"- 212page PDF!- Thanks Bob! :cheers:
www.video.google.com/videosearch?q=datron- DATRON Milling Machines on Google Video! - thanks Xerxes!:cool:
http://www.books.google.co.uk/books?...ct=result&cd=1 - "Polymers in Concrete"- Papers from international experts from 13 countries...
http://www.epucret.de/index.php?seit..._en&root=26650 - "We are using machines with Polymere-Concrete frames for years. These are the best machines we ever had. Very stable and high accuracy. Epucret is a frame manufacturer for Mikron/Hermle etc..." - thanks Aramon!
http://www.moldmakingtechnology.com/...es/040401.html - The Secrets to Hard Milling Success!
www.corsair82.com/corsair/vacinfs/ - vacuum degassing process...
www.joewoodworker.com - "Woodworkers are fortunate people".
www.masterbond.com/tds/ep30lte.html - MASTER BOND POLYMER SYSTEM.
http://www.aircraftspruce.com/catalo...s/aeropoxy.php - "Aeropoxy From PTM&W Industries".
www.shopmaninc.com -Again... "Low viscosity epoxy like 30 bucks a gallon" - mention Larry when you call them!:D
www.pyramidgranite.com/index.html - Whoa, this stuff looks cool! :eek:
http://www.microplan-group.com/pagin.../celith_gb.htm - "..a little more info on making E/G" - thanks Bruno!
http://www.diamond-drill-bit-and-too...Drill/MAIN.htm - Diamond Drill Bit and Tool.
http://www.harborfreight.com/cpi/cta...emnumber=42947 - Concrete Vibrator... Lightweight and easy to use- plugs directly into any standard 115V outlet! :p
http://baryon.as.arizona.edu/TECH.php?navi=gload - how to make a "really big telescope mirror"- Incredible!(flame2) (flame2)
Many Thanks to All the Contributors!
:cheers:
