well the first thing i see is that the Z axis safe travel is only 0.2mm above the work and that isnt anywhere enough if you have home set wrong that will cut lines all over the place
Printable View
what cutting tip are you useing
point
ball end (what size)
Not sure what size the tips are but they came with the machine. I am engraving onto vaccuum metalized plastic which is appro 2mm thick. What would you recommend as a starting point for these settings;
Separation (between letters is set at) 100%,
Rapid Height:
Height (of letters is set at) +30.0000
Z Top:
Depth of cut:
I appreciate any help you can give.
Brian
ok well i dont generate my g-code with mach3
i use Google SketchUp with an addon called SketchUcam draw it up in that and then use the addon to export it to g-code
there are a bunch of youtubes about how to use it
Just had a look - by god those wizards are awfully designed - how hard would it be to include a brief explanation of each parameter?
You need to put a value in for rapid height. Assuming you've zeroed your Z axis such that it corresponds to the tool touching the surface of the work (otherwise the "Z Top" value would need to be something other than 0) your Rapid Height wants to be a couple of millimetres, say 2 or 3 - this is how far it raises the tool when moving between engraving positions.
I assume you're setting the Depth of Cut appropriately for the material you're using.
I noticed that you are running mach 3. Do you know anybody that support this software in Australia?
We are trying to get a CNC machine up and running with it.
No, I don't know about Mach3 distributors - mine was supplied by the people that sold me the machine.
Thankyou for your reply.
if you have a legal copy of it then just email them about the problems you are having and if they have a dealer / support tech here they will tell you where they are
are you Steve Boutin sbsigns USA or stewart Boutin sbsigns au as there are SBSigns in lots of places
if you where in QLD (your not) i would have given you a hand with my limited knowledge if i could have
hmm maby you should have picked a different name lol all of these fly under the name of SBSigns
http://www.sbsigns.com
http://www.sbsigns.com.au
http://www.sbsigns.net
http://www.sebasigns.com
http://www.sbsignco.com
http://www.sbsignanddesign.com
Signs, Reception Signs, Vehicle Signage, Banner Signs, Brookvale | Stewart Brown Signs based in Brookvale NSW Australia
Figured I'd wave hello, Cody here from North Sydney. Currently building a 650x1300 router.
A few more details in this thread, can anyone help me out with where best to source steppers? - Best place to get Steppers(AUS)? | CNC Router Zone-For professional and hobbyist alike!
Cody,
I don't know, but I got my machine built by Justin at Vermec Engineering here in Redcliffe. He makes quite a few, and has a good rep - sources good value but good quality stuff - not sure if he sells parts but worth trying them: Vermec 07 3284 3733
Andrew
Hi Cody
Got mine from china, the big ones, longs motors. The whole setup has been great, motors, controllers, breakout board and power supplies. Mine are the largest ones they make, about 5 kg each. Price was good, a week to arrive. Check ebay.
I found the local suppliers here in nz were adding 200% margin! too expensive. Also they will give you a low customs vale, saving even more $$
Never had issues with them, run like a charm on my mill
Shaune
What freaking language do you guys speak on these forums? Nano jingling?
Enroute user here...and happy with it. Very old retrofitted Esab, converted to Tekcel about 15 years ago.
(Though on rare occasions I've wondered about gutting the machine and putting Geckos and Mach3 in, but generally I've got around the issues, and we plod along. You learn to nurture the machine like an elderly relative!
