9 Attachment(s)
Small Project Distraction
I picked up 1-1/2 old Southbend Lathe tool post grinders from a fellow Zoner and started fixing them up. Not a bad little project. I still need to finish grinding, clean up and paint but it seems to work great.
I'm not much of a welder but I scabbed together a belt and wheel guard from some flat plate I had laying around. I cut strips out of the plate the formed them for the belt and wheel guard portions then welded.
I took one of my messy shop with welding stuff scattered....
Here goes....
3 Attachment(s)
Finished another pulley....
Just waiting on the broaches. They are suppose to be in Wednesday but of course I'll be out of town.
I couldn't stand it so I re-did that spindle pulley.
Question - Spindle Threads
I'm going to have to do some trimming somewhere. The splines on the spindle only stick up out of my pulley by a 1/4". I see where I can easly trim another 0.375" off and that will allow 0.500" worth of threads and a little clearance on my Spindle Nut.
This is the nut/hub my PDB will pull against. I think with 1/2" worth of fine threads and a shoulder for the nut to butt against when tight, and a set screw ought to handle the pressure okay. Opinions?
My only "other" option is to machine some off the shoulder on the bottom of the spindle cartridge but I rather not do that unless I have to.
Richard
