Originally Posted by
Vern Smith
Last night my TM-1P umbrella tool changer forgot where it was. The changer moved to the spindle and clamped onto a tool. Unfortunately, the spindle moved up before the changer retreated to it's home position. The result was ugly as one would expect. The spindle pulled the changer up about and inch or so before the fingers spread enough to release the tool with a huge bang. The machine alarmed out at about the same moment with code 125 - shuttle fault.
I did the recovery sequence with no problem and everything works although out of alignment. I'm sure everything can be straightened out and brought into specks but my concern is the switch/sensor/gizmo that failed and will doubtlessly fail again.
I would appreciate any information on this problem, and particularly what switch/sensor/gizmo has gone intermittent and needs immediate replacement.
Thanks Vern
