If you can see the solenoid activating and turning on 16 bit 7 check your relays
If you can see the solenoid activating and it is not change sensor
Printable View
you mean if solenoid activating and turning on 16 bit 7 then i have to check relay...ok but which relay..
can not understand what do you want to say///(If you can see the solenoid activating and it is not change sensor)
There is a cover on top of unit about 65 dia take it off to see solenoid I can't remember exactly what relay I think it is top row 2nd and 3rd from right I do not have drawings in front of me
i have a wiring diagram if you say i can share with you..
and this is i confirm you that solenoid and both sensor are work fine the only thing is encoder metal ring not come under the locking control switch
Yes share I will advise when I am not at work
ok thank i will share you tomorrow
I look forward to it
dear brother please check attachment for wiring diagram
regards
fsa
5 is your shot bolt and 6 is turret reverse replace them
ok but one more thing i want to tell you before replace the relay..that turret is working in both directions for example when i call tool #1 the turret rotate ccw direction stop at position 1 but not locked so i have to press reset button and then call tool#8 the turret rotate cw direction and stop at position 8 still not locked so i again press the reset button .........its look that turret rotate both ccw and cw direction.......NOW please tell me Sir..still we need to replace relay 5 and 6????
regards
Fsa
Along the top from 4 to 8 are the relays for your turret check they are working. 6 is your shot bolt had this last week changed 5 and 6 started working however you have never said it works in reverse before
Good luck
.as I said ages ago have you checked you are getting 24v to the turret
i am confused sir ..
ok first i check 24v at turret.(please point me in attach pic where i check 24v )
then replace relay with new one
ok sir as per your instruction i have check 24v DC and it is coming at turret .
about relay ..i check relay form 4 to 8 .......and as per my understanding relay work well...
how i checked now i am telling you .
1st i call tool#1 the turret rotate CCW and stop the position1 (but not locked)
now i remove relay #4 and call tool#2 but no response in fact in jog mode manual tool change is not activating.
then i reconnect relay#4 and do same process like above mention and the turret work ..i apply this procedure on all relay #4 to 8.
except relay # 6 all relay showing difference when connected and not connected...relay# 6 show no change either connected or not connected..\ ...........now what to do
Sir still finding the solution..
Check turret motor proximity sensor gap/clearance is correct,then reset turret timing as mbservice advised earlier.this sensor could be faulty/breaking down.
Jono1961 thanks for join our conversation... r u talking about 6# sensor please check jpeg...highlighted with black circle?? i already maintain the gap between sensor and metal ring as per manual instruction..its 0.8mm to 1mm gap..
2nd thing i dont know how to reset the turret timing can you guide me please
regards
Fsa
dear are you talking about this sensor can be faulty please check attach jpeg highlighted wit yellow lines..
regards
asif
See attached photos
I - Locking control switch
6 - also Locking Control Switch
Sorry not certain how to upload better quality pictures
https://www.scribd.com/doc/22636513/DUPLOMATIC-TURRET-1
no photo only manual of turret ...so what i do now????
The pictures and information are in the turret manual too if you look.
ok jono 1961 so your advise that i change locking control switch and reset the turret timing..but how to reset the turret timing can you guide me please.
