Ok. I know the contacts your talking about.So I should connect the inveter to the N.O. contacts in order to control spindle fwd/rvs at machine control? Also the spindle speed is controlled be the variable speed milling machine head.thanks again
Printable View
Yes if it has a relay output, just use the contacts to control the VFD, make sure there is nothing else connected to the contacts from previous control to any other part of the machine.
Al.
Tomorrow I'll disconnect the two wires that go into each contact and plug the inverter into them.I'll let you know what happens then....thanks again
Mike
If all you have are the contacts on the old motor relays, or your controller has relay closure outputs, then this (see diagram) would be the connection scheme, as per Al's post.
Steve
I have POWER!!!! Thanks everybody for your help.. My next task is an inverter to my manual lathe which should be similar power to motor and the inputs to fwd & rvs. Thanks again:rainfro:
Hi guys,
Now I'm hooking up a Kerry lathe.Now this one I beleive should be easier..Do I hook inverter right to motor and then the p24 and 1 and 2 to a switch? The orininal switch used to divert the power so I'm gonna get a smaller one.Does this sound right??Thanks:confused:
You can get three position switches with a centre off, one side = Fwd and the other side = Rev.
N.O. contact on each side.
Al.
When I hit run the motor turns on and the switch isn't working. ( my switch may be too big I'm not sure ). Do I have to progam the inverter to see the switch? I'm not sure.... Thanks
Did you switch from keypad to external mode?
Al.
no, last time the technican walked me thru it. I'll have to try and find it in my book
Thanks everybody for your help. everything is up and running.I'll post pics soon:rainfro:
