U10L same U100L jumpers
OSP-700L same OSP-7000L jumpers
Printable View
hey kurmay ! secret ?
It is no secret that the two people know :)
i hope i got it right : you are Okuma :)
Does anyone have experience with floppy-ethernet emulators? Some random guy fried the board handling serial transmission of our machine a few years back and since then we have been running with a floppy in our hand to the machine and back to the computer. I would rather see our machine connected to the ethernet via the floppy emulator than run with a usb-stick to the machine and back. DNC/repair costs $7000+. Not an option right now.
the link from 1st post in this thread is broken, but there is a clue ...
please consider contacting morris midwest, maybe there is a chance :)
Quality Machine Tools and Engineered Solutions - Morris Midwest
hey myhaje, check this out : 300723408804 | eBay
Ok, so I just recevied this:
White 3.5 1.44MB USB SSD FLOPPY DRIVE EMULATOR E100 Version for SFR1M44U100 White 3.5" 1.44MB USB SSD FLOPPY DRIVE EMULATOR E100 Version for SFR1M44-U100 | eBay
Tried the Jumpers at: M0, S1, JA, JB
And also at: S1
Still getting a disk Error
OSP-700L Controller
Kurmay, any Ideas???? Thanks for your help on here!
What is it that I am missing?? all the other emulators have worked great!
Just this **** Okuma!
our 1994 lb35 with osp7000 controls the floppy drive is on the way out and we want to convert to a usb stick drive . found a drive that is so called made for our machine comes on but throws a error is there parameters that need to be changed
Just wanted to chime in here with what worked for me. Used a 3 digit display USB, OSP-U100M on my Okuma. Had jumpers setup as instructed but was getting errors as well....found that I could view the files without issue when using MS-DOS mode.
Thanks! It's almost perfect but still need help.
Got a grey 3 digit sfr1m44-fu and installed on a OSP-7000L lath. Stock nothing worked. Changed jumper as per Kurmay's post and it got much better. I can copy both directions in proprietary format (OSP?) and can copy files from PC to USB to lath in MS-DOS format.
I still can't copy MS-DOS format to USB and see the files on PC. Both proprietary and MS-DOS files are copied to USB correctly (NC indicates successful copy) but then I can't see them on PC, only on NC. Not working either with folders created by PC or by the emulator drive.
Any ideas?
I have had a unit from Gotek model SFR1M44-FEL-DL and I'm having a similar issue. If I copy a file from the PC to the USB and then try to read it on a 7000L control I see no file (this is in MSDOS mode on the control). If I then copy a file from the NC to the USB the copy says its finished and a DIR shows the file. Back at the PC I cannot see the file only the file I originally copied on the PC. So similar to what you are seeing very strange.
:confused::confused:
HI Kurmay,
Would you know the configuration on the E100 controller by chance?
can someone post instructions for transferring programs from USB to control ? with the emulator ?
Hello there please help me
I have bout an okuma mc4va center milling machine but it does not have floppy disk and floppy to backup the system. I want to know if I buy a floppy emulator I can able to back up all of machine data?
Please let me know ????
has anyone gotten the u10 or u100 to work with both msdos and osp on these 2 or 3 digit usb emulators?
Hello,
on Monday I installed the normal SFR1M44-U100 with 3 digits for PC use in the OSP E100L. You need 3 jumpers for MO, S0 and JA. This is the same configuration as the floppy drive and runs fine.
