here is what I found on the tension. I tried sending in in PM but said your inbox was full. Hope this helpsAttachment 475792Attachment 475794
Printable View
I don't know why this happened. I had just few messages in PM's.
Thanks for settings info, it will surently help.
I thought every alpha has a possibility to cut in submerged mode...
I don' know if they are all or not but I know mine the drain system is such that it cant. Like the back is open for the water to drain out of instead of like a tank with a drain hole. There's not a button to fill or drain tank either. Friend that came up gave me some good ideas and explained some of the power settings that I am going to try out. I was doing a few things backwards. Hopefully I can get it all figured out. He explained the De ionizing system and stuff also. If you can send me a PM with an email and a physical address I'll send you a copy of this class workbook if you want. it has some things in it that are explained better than in the manual.
I would gladly see what it looks like, and also share what looks like cabin for submerge cuting. I tried to cut above the surface, but it was like trying to find a compromise between eficient cuting and splashing all around.
I can understand that for sure. I wish this one was submerged.... I did learn that I have been going to wrong way to speed the cutting by upping to voltage. The guy this weekend showed me that lowering the voltage made it go a little faster. Haha there's a lot to these that doesn't go logically :)
