And finally, here it is together and ready for binding, armrest work, and lacquer. Will post finish pictures by the weekend.
Attachment 360762
Attachment 360764
Printable View
Attachment 360762
Attachment 360764
Here's a few pics now that the lacquer is done. Was a good night. It took about 3 hours to level sand (600 grit) and then buff (med and super fine) the finish. I follow Robbie O'Briens finish schedule from his online course His schedule makes the final level sanding very easy.
Here's a sample: https://www.youtube.com/watch?v=DITuYQeas5M
Attachment 360988
Attachment 360990
Attachment 360992
Attachment 360994
Attachment 360996
Attachment 360998
Pictures of #12 (mostly) finished. Just need to intonate the saddle. This was an amazing setup. The frets were so flat I only need to level 2 of them, then the initial setup
came out perfect, no adjustment needed and 6/64" clearance at the 12th fret!
I have no idea why the pictures are sideways.
Attachment 361140
Attachment 361142
Attachment 361144
Attachment 361146
Attachment 361148
Attachment 361150
Attachment 361152
Attachment 361154
Attachment 361158
Attachment 361156
Here's a video of the initial string-up/play. Note to aspiring builders - initial setup never sounds this good. This thing had perfect action by pure random chance.
https://www.youtube.com/watch?v=dyU297z3hgE
That is a beautiful guitar! I love your process. I have created two electric guitars on my cnc mill, at work. A Les Paul, and PRS. I have a couple of questions for you. What do you use for a vacuum pump? What do you use, cutter wise, for making fret slots? Speed and feed settings?
Thanks.
For the pump, I use the same vacuum pump I got form joewoodworker.com. Meant for doing the vacuum bagging, I just put a different type of hose on it to push into the vacuum jigs.
I use the fret cutter bits from precise bits.com ... BUT.... it is .025" bit, and I found that my slots are little too loose on the fit, so I've started using the .020" shell cutter bits to make they're snug. Maybe spindle runout causing that. I do .010" cut per pass, rather slow (whatever they're listed feed rates are). Running bout 12K rams IIRC.
Love your designs!
