2 Attachment(s)
Re: Milli a new composite mill kit
Morning All & Lurkers - Today brings the steel fibre investigation to a close. Block 4 has been cut out of the bucket. Its quite solid and there was a lot of paste on its top. At best it has 10% by volume fiber in it, which gets 34 low and 40GPa high in modulus. So I may as well buy grout that has 34GPa out of the bag. So I need to get some ALOX, SiC or Alumina to get to E70+. I shall try to get north next week for some ALOX. I'm tempted to knock back the material spec in Milli to 35GPa and move along.... material development is a tough gig.... Peter
1 Attachment(s)
some info on damping - Peter
1 Attachment(s)
Evening All - Here's a historical lifting gantry machine, been busy finding some SiC and Alumina in china....... Peter
1 Attachment(s)
Evening All - I use Rule of Mixtures a lot thru here so I thought I'd include an example using some moulded plastic. Zytel 35% fibreglass has been around for a long time and has pretty std properties.
A simple explanation of ROM is if you add a glass of 50C water to a glass of 100C water you get 75deg C water when mixed...
https://dupont.materialdatacenter.co...35HSL%20BK039B
Using the attached data and ROM calc shows the strain efficiency of the combination is n=0.85. In my calcs I have always used 0.5 as this is the bottom conservative figure. This is called "translation" ie how does the theory translate to reality... rounded particles don't transfer strain as well as longer fibres do... so round ed (like sand) tend to the 0.5 figure.. I'm getting some ALOX this coming wednesday if I use 0.5 solids ratio (by volume) with CSA I should get E90 (n=0.5 in both). If I use 0.6 solids and epoxy I should get E77 so they are my targets. If I use epoxy its about $17200AUD per m3 and if I use cement its about $11000AUD per m3 so hopefully the grout approach works out...I'm sure I can infuse ALOX I have infused sand before a few times.... Peter
Hey Peter,
Have you thought about the anchors yet? Options:
1. thinner mounting plate + (more) thinner anchors (more balanced?)
2. thicker mounting plate + (less) thicker anchors
Quote:
Originally Posted by
peteeng
Yes a nice old planer if you can find one that size it most likely will still do a very good job a lot of machine builders added a milling head
2 Attachment(s)
Hi Ard - I have two thoughts 1) cast the aluminium blocks in then machine all the required features into those blocks on a large router or VMC 2) cast in pockets then epoxy in anodised blocks then finish machine . I'm leaning towards 2) at the moment.... Sometimes aluminium and concrete don't like each other and the Al corrodes so epoxy is a good barrier. If I use steel I'll zinc plate them prior to in-situ casting or post placement... Doesn't affect the CAD work at the moment. Haven't had luck getting the Alumina I want local but a chinses company is quoting on a suitable spec. Local blasting grit is a bit more cost then it should be but it will be fine for casting test blocks, fingers crossed some may arrive tomorrow. I have made the CSA test blocks into trivets and they are now in my kitchen.... I will need to get some granite sealer they are a bit porous and suck up stains.... real machine parts will be sealed and painted. I'll have to get Gully onto that he's good with paint....
Using local materials ALOX/EP E90-95 ~$17000AUD per m3 ALOX/CSA E80-85 $11000 AUD per m3...... Plate Alum at $9/kg $24300 AUD per m3 so not bad.... Peter
CSA CTE 13.7 ALOX 8.1 Alum 21 steel 12 epoxy 45 cast iron 11 units um/m/C
Yong Ju make big machines. I do like BIG machines....
peteeng
thats a planer.
it only takes force in a single direction in a very controlled manner.
doesnt really apply much to a multi axis cnc.
peteeng
If you are going to have the machining done outside then go with steel inserts it won't cost any more to have the steel machined vs, aluminum
Hi Mactec - Agreed if I contract the machining then st or al does not matter. Once I have a mill I can machine moulds that only have thread inserts vs "blocks". I'd prefer aluminium but will decide once more detail is filled in. Peter
Hi All - The usual issue with mixing materials is the CTE delta. If I go with the ALOX/EP and I use 60%V alox and 40%EP then the CTE is (0.6*8)+(0.4*45)= 22.8 which is close to AL @ 21 , ST is half that. So aluminium is a good match.. If I use CSA then (0.5x13.7)+(0.5*8) = 10.9 which is closer to steel so the use steel.. Peter
Video from Keith Rucker about a metal planer he is restoring: https://youtu.be/OZWD8PlDwn4
Evening All - I have 25kg of ALOX being delivered tomorrow so can continue the struggle for the Holy E70!! Peter
Hey Peter,
Hope you got that alox today.
https://i.imgur.com/hziPhBl.png
Inside the spindle box, had to do an extension between the spindle and the cartridge, alternatively I could run it direct drive, but no way to do regular belt drive without compromising the structure of the bridge. I really want the bridge to carry most of the motor weight as close to the middle of it as possible.
I'm not sure about the extension though, particularly the bearing config https://i.imgur.com/9xzCViQ.png
Hi All - waiting for ALOx looks like today. In the mean time I've been playing with the laser. Up to getting the CAD/CAM to talk to it. But I pushed two buttons in sequence trying to do something and it "reset" it cleared the memory of the machine!! Bummer. Now I'll have to figure how to set up the machine variables from scratch with no documents. The ARGUS mountain just got a little taller... Peter
peteeng
yes, and the bridge is between the columns ;)
Hi All - Been away for a couple of days. ALOX now in stock may do the first test tomorrow.. Peter
Hi Ard - Thanks Sudholt-Wasemannn have a lot of info about UHPC on their site.. Got home yesterday from a shirt trip and my main computer didn't boot!! Seems it liked the rest so much its staying cold... So its off to the tech tomorrow. Can't use my CAD system so I'm forced to do some ALOX casting.... :) Peter
peteeng
Hey good to hear from you, I was wondering whether one of the outback beasts ate you or something...
Actually that data is direct copy from durcrete, here's the original repository:
https://durcrete.de/downloads-english/?lang=en
