Anyone Modify this to accept incremetal code
Quote:
Originally Posted by
Switcher
You don't need Vb.net to run the program, you will need "
Microsoft .NET Framework Version 2.0" (Download & install this If it's not already on your PC before you run the Gcode2DXF).
After you download the .Net Framework 2.0, then download the .Zip file
here (latest version post #49).
After you have the 2 downloads on your PC, unzip the "Gcode2DXF .zip file" & follow the path below to the program (assuming you downloaded the "Gcode2DXF .zip file" to the desktop).
...\Desktop\Convert DXF SourceCode\Convert DXF SourceCode\Convert_DXF\bin\Release\Convert_DXF
:cheers:
Just wanting to know if anyone has ever modifed the program to accept incremental code.
1 Attachment(s)
File not converted properly
Can anyone tell me why this file does not convert properly. It creates the outside of the part but does not bring in the circle in the center of the part
