Seems like Love hs has got alot of the buisness.
Has anyone gotten the NEW 4KW AIR-COOLED SPINDLE MOTOR ENGRAVING MILL GRIND
to try?
I'd like to see an ER25 collet rather then a ER20 seeing my ekstrom carlson spindle is ER25 and then the collets would be common. Although I suppose on the flip side it's probably better to keep collets with a spacific spindle so having separate sizes would cure that.
question is, is his inverter any good? if not I'd probably go with a micromaster setup from BILL BOWLING
[email protected] As he sells an inverter which is good for 2 phase input up to 4hp or so in the micromaster line.
Also does anyone have a mounting/bolt pattern/measurement/cad for his 4kw air cooled spindle?..
And has anyone gotten one to see if it's any good?
Thanks.
b.
