So does the a1 terminal play a part or do I just wire it 1 nc to the bob and the other nc to the relay/on off switch
Printable View
Hi Michael
on the KJD17 switch terminal A1 needs to be connected to terminal 24 via one of the E-stop N/C contacts
the second E-stop N/C is connected between the BOB E-stop input ( usually pin 10) and the input common
Attachment 437602
Attachment 437604
when the E-stop switch is pushed the KJD17 switch will switch off killing the supply to the spindle and stepper driver power supply
the BOB will signal an E-stop to the PC
John
PS
it looks like I will have to find the original diagrams used to produce the spindle wiring diagram as the diagran here on cnczone has a reduced resolution in post 103
note - the KJD17 switch shown is the UK version with a 240V and you need the USA version switch with a 120V coil !
john the 1st post to the drawing looks like it started on post # 24 but it is missing the no volt on off switch
John I was wondering if you know anything about a spindle sensor for a mini lathe to be able to thread ? I have just bought a mini lathe and I am converting it to cnc and I need to get something for threading and I was thinking could I use this same setup that I have for the mill for the new mini lathe just with 2 axis?
Hi Michael
with the mains supply connected to terminals 13 & 23
when you press the green button terminal 14 is internaly connected to one end of the coil
the free end of the coil is terminal A1 that needs connecting to terminal 24 to latch the switch ON
by connecting A1 to 24 via one of the E-stop switch N/C contacts
the switch will open when the E-stop switch is open
Attachment 437820
the E-switches second set of N/C terminals can be connected to the BOB's input pin 10 & common to signal an E-stop to mach 3
is this any easier to follow ?
John
yes you have 2 wires connected to terminal 24 -
the connection to A1 via the E-stop and power to the spindle controller and DC power supplies
As it might not be easy to crimp 2 wires in the quick fit connector you push onto terminal 24
you will find it easier to connect 1 wire between the switch terminal 24 and the Live input to your 5V or 36V power supplies
and the wire to the E-stop switch
how was the power originally distributed ?
power looped from one power supply to the next and the spindle control
or are there terminal blocks distributing the power ?
John
