Reaching a point with radiused tool on mill.
When using G41 or G42 Offset.
I find my Fagor controller will run some tool paths and not others and haven't yet found what the criterion is.
The code is all G01 (NO G02/03) and it refuses to go to a point.
The point is usually very close (.01) to the adjacent points.
I contend that a tool with a radius cannot reach a point between two other points (G01) where the angle of the three points is less than 180deg.
As the controller processes most of the tool path, there must be a criterion where it rejects the code. eg four decimal places?
Any others have the same problem?
