Deckel Maho DMC 63V Z axis intermittent drop.................need help
Could anyone here help me to solve the intermittent Z axis drop problem on DMC63V?
Mostly happened when doing manual setting (using handwheel) or when closing access door and press Feed Start. PM to my email is also welcome.
:confused: :confused: :confused:
Thank's in advance.
Hi Guys,
I am facing the same problem as Kevork since last week. The Z axis drops whenever we open the Door or when enabling/disabling the axis using hand wheel. There is no change on the controller when this drop occurs and the Z axis axis goes back to its original position with a jerk and big sound when we close the door or operate the hand wheel. I called Fanuc India as well as DMG office. They both suggested that the problem is mechanical and to check the belt , ball screw coupling etc. I have have know bypassed the door lock and machine seems to be working fine. But I am afraid whether it can drop suddenly while in operation and cause damage. Fanuc engineer is expected to visit us in couple of days time. I suspect there is some problem with the relay or servo motor brakes . Plz help guys.......
