5 Attachment(s)
myCNC - CNC control software
I'd like to announce myCNC software.
myCNC software works with myCNC controllers (USB, Ethernet/LAN, RS485) and drives up to 6 axes motion and rich peripherals (like PWMs, ADCs, DAC, relays, transistor open collector outputs, binary inputs).
myCNC is the first multi-platform CNC solution and works under Linux, MS Windows, Mac OS.
Main features:
* True Multi-platform solution.
* Graphical User Interface (GUI) including Touch Screen version;
* G-codes interpreter/compiler with 2D/3D visualisation (Visualisation of linear axes XYZ and rotational axes ABC), zooming/scrolling/rotation features;
* True multi-tasking. Working in Shapes Library or NC Graphic editor is available simlultaneously with machine operation;
* True simultaneous 6 axes interpolation (linear, arc, helical, spline, nurbs(*));
* Flexible controller peripherals control through integrated PLC (Programmed Logic Controller);
* Flexible screen design through rich XML-based configuration system;
* Shape Library with row and column nesting features;
* Stand alone mode support - working myCNC control without PC connection;
* Internal G-codes editor with 2D/3D visualization;
* DXF and HPGL CAD files import, export(*);
* Forward and Backward running mode, step running mode, easy restart anywhere along the programme, full reverse along cut.
* Complete network support, wifi solution available;
* Flexible rotate, zoom and flip transformations;
* Look-ahead features with Automatic small hole slowdown;
* many other features;
myCNC control software is free and available for download, evaluation and testing on our website.
2 Attachment(s)
myCNC - CNC control software. new version available.
myCNC -version 1.75 is available.
- Number of G-codes implemented (G65, G68,G69, G74, G75, G80-G86, G98, G99 etc);
- A lot of GUI improvements;
- ATC support;
- Constant velocity mode with flexible buffer look-ahead;
- Big files support (tested for 100M nc-files);
- Many others;
