Originally Posted by
jduke
Mactec, it sounds like your pretty deep into DMM motors and sold on their benefits.
as a home hobby guy, I am still having difficulty with spending over $2000 on 3 motors when I still have to replace the spindle motor as well on this machine.
I had a Nema 34 12nm rated closed loop stepper motor that I popped onto the dm4400m this morning and was able to move the each axis with it well on X and Y I was able to get up to over 1000mm/sec^2 accelleration at 5000mm/min before the closed loop kicked the motor off
the cost of 3 12nm closed loop steppers is under $500 for the Mophorns that I have.
I can spend the $2000 on motors if it will really get that much better performance, but having never used AC servos in the past, I am having some reservations.
I am also probably only going to put a 2-3hp spindle motor on this machine, is having the excellent performance of AC servos going to be wasted with such a low HP spindle?
as it stands, I have 1800 in the base machine, and another 1000 in the spindle cartridge, so another 500 for a spindle motor
if I go with AC servos that would put me up to 5300 into the machine with the closed loop steppers Id be at 3800.
like I said, I am open to doing the AC servos if they would really up the performance, but I am having some reservations.
thanks for the input.
Duke
