Re: Cnc router electronics
all steppers lose torque the faster they go, thats plain physics and you can't get around it.
The inductance of a stepper is a good measure of how bad that torque degradation will be, the lower the better. For example a 269oz.in stepper of 5mH
inductance probably will have 5% or less, ie 13 oz.in at 1000 rpm, whereas a 260oz.in stepper but only 1mH may have 100oz.in at 1000rpm.
I think your 23 size 269oz.in steppers are about right but they MUST be low inductance or you will be disappointed.
The second way to defeat the degrading torque is to use the highest voltage drivers and power supply you can. Don't waste your money on a 24V supply,
that wouldn't pull the skin off a rice pudding, and those TB6560 drivers have a poor reputation for lasting. What you want is 80VDC capable drivers,
about the highest voltage of regularly available drivers with an 80VDC linear (transformer/rectifier/capacitor) power supply.
Craig
Hi GoCe - Agree with Craig. Go higher voltage. 48V is your next step as low cost drivers are about 50V max. I've built 12V systems and they just don't work. 24V is OK for N17 motors that go slow. Your N23's are good. The 20mm pully will give you lots of speed but low force. But if your only cutting wood and plastic thats OK. Something like a 700W makita router is great but noisy. Look for DC spindles on ebay with ER collets. Same price or less as Makita cuts nearly as good and they are quiet. I've cooked a few TB6560 drivers wouldn't use them,,, 16mm ballscrew is big for Z axis 12mm will be cheaper and just as good 5mm lead is good for Z axis.. 15A PS is expensive and overkill 10A is fine....What rails are you planning on using...cheers Peter
Hi GoCe - 4 x 3A motors is 12A max. All motors do not operate at max at the same time. Maybe half that or 60% max so 6A to 8A maybe. You can't fry the PS by drawing current from the motors. The driver has a current chopper to protect itself so you set the max current at 3A or 2A etc. The electronics guys can explain this better. If the PS fried it was shorted somehow not the motors fault... 100ipm is 2540mm/min which is not fast. I expect it will have lots of force to cut timber and plastic. Without doing the numbers I used similiar motors on Gecko 540 with 3A setting and usual cutting speeds where in the order of 1000-1500mm/min. I did finishing cuts on some jobs at 20,000mm/min I used a 20T pulley as well. I use a 16mm wide belt 5mm pitch AT type. Workes fine... Peter
You will not get good performance if you use your 269 oz in, 24V power supply and TB6560, I am sure
For 120cm x 80cm cnc router, it is better to use 570 oz-in motor and 48VDC power supply
I would suggest you to use the following parts
Stepper Motor: 570 oz in
https://www.automationtechnologiesin...23h2100-50-4bm
Stepper Driver, 5056
https://www.automationtechnologiesin...-driver/kl5056
power supply, 48V
https://www.automationtechnologiesin...upply/48v12-5a
Breakout Board, UC100 USB and breakout board
https://www.automationtechnologiesin...mach3-usb-card
UCCNC software
https://www.automationtechnologiesin...ntrol-software
if buying 23 size steppers look for as low inductance as possible, 1mH preferred and reject anything over 2mH.
In order to make low inductance steppers manufacturers use fewer turns of a thicker wire, which in turn requires more current to get the same
torque. Thus the steppers you are looking for will tend to be high current devices, say 5A or more. The 570oz.in motor linked to by the previous poster
has an inductance of 2.5mH, so on the high side but still quite respectable.
I'm not a fan of switch mode supplies, they are too tender. Linear supplies like these:
https://www.antekinc.com/power-supplies/
Are very much more robust.
One of the most common reasons for failure of witch mode supplies and/or stepper drives is BackEMF at deceleration. All motors generate
energy back into its nominal supply when the motor is decelerating. The ability of the driver and/or supply to tolerate these overvoltage events
is the principal difference between good and bad driver/supplies.
Gecko is the industry standard for robust drivers but are not cheap. There are plenty of good Chinese made 80V drivers at very fair prices...get some.
Remember you'll have these drivers and power supply for ten years or more if you buy well in the first place, but throw them out in months or less if you buy poorly.
Craig
Hi GoCe - You may have trouble fitting 20mm wide pulleys on your stepper shafts. So look at that closer. Plus look up the moment capacity of the motor bearing. If you mount the pulley away from the motor to use the wide pulley it will bend the shaft. Get larger shaft versions of the motor. Belts work best when tight and this tension will fatigue small shafts... Peter
From your comment on rails I assume you mean steel section with skate board rails. If this is the case I suggest you look at round rails. They will cost th same and perfom much better. Many skate bearings on a rail although doable and initially looks good requires much alignment and many bolts and holes. Round rail is simpler and more accurate and will be similar cost. You can save $$$ on electronics (and upgrade later) but put the $$$ into things that matter more eg the motion system.
Quote:
and i think 269 oz.in will be ok even with bigger inductance,
Good luck.
Craig
Power supplies: you can get good 'bricks' from ebay for very little $$.
I replaced my under-sized transformer w diodes, caps etc, with bricks, and got 5 V, 24 V and 60 V all at 10 A.
They have survived some mishandling.
Cheers
Roger
Hi
the stepper to which you linked has an inductance of 1.8mH when wired i bipolar parallel and is a far better choice than you original 269oz.in 5mH ones.
Craig
They're 5.66A (parallel) which sounds really high (for 57x84 400oz) and would seem to rule out a lot of drivers, e.g. DM556.
Hi GoCe - Use proper round cars and matching round rail. Not commercial tubing, Won't work. Linear rail is hardened and ground to a specification. The car balls will gall the unhardened steel or aluminium tube. Peter
what you think about SBR16UU linear bearing block on steel/aluminum tubing, can it work??
Of course it will 'work'.
Those hardened steel balls will work lovely grooves into the soft steel or aluminium tubes. After the first couple of passes there will be no more drag at all. Could be a little slop and rattle of course.
Cheers
Roger
PS: the above 'approval' is not meant to be taken seriously.
