2 Attachment(s)
Pot number in magazine not matching pot number in control
Hi Everyone,
I have an issue with the actual pot number not matching the pot number in the control. (Fanuc 16i-MB) I have been working thru the manuals but have not found a clear procedure on how to reset this. The machine has just been moved to our location and we are getting it setup. See attached pictures.
Any help is greatly appreciated.
Thanks!
K
Re: Pot number in magazine not matching pot number in control
And the problem is ?
If you have a tool change arm that holds both incoming & outgoing tools, then your pot & tool numbers are always going to get mixed up.
It would be nice to get them to align occasionally.
Simplest & error free method is to shuffle tools into their respective pots using MDI.
Next method is to change numbers in the parameter file...(could renumber wrong tool, chrunch time)
Ussualy it is used the DATA TABLE to store the tool numbers in the pockets
Look in the PMCPRM window on data table to see the tools are ther eand rearange it manually like 1-1,2-2,etc
