Puma 2600 SY
Dear Sir,
I am using Puma 2600 SY machine
I am facing 2 different type of problem in this machine kindly see below for details
Problem 1
G40 ,G41, Command does not function properly,
Found in spline milling operation cutter compensation is taking 2times of radius mention in the geometry offset.
Problem 2
Slot milling C1 & C2 command execution malfunction
found C1 & C2 Axis commands are using simulations the problem was observed,( zero position not correct)
after continuous analysis its confirmed by giving end of block (eob) before and after C command the position zero come correctly.
regards
Charles
