Re: Z axis tramming question
You need a dial indicator and some kind of an arm that you can chuck in the spindle (the photo is not mine, just found it in the interwebs):
https://www.model-engineer.co.uk/sit...036/720739.jpg
You rotate the arm and take the dial readings in four opposite points of the table (east-west-north-south). If the spindle is perpendicular to the table (and the table is flat), the readings will be the same in all 4 points.
Seems like what I’m looking for. Thanks!
