3 Attachment(s)
How to tell F360 where to plunge outside of stock for pocket clearing
I am trying to do a 2D pocket clearing op. One edge of the pocket is at the stock edge so I want the cutter to start just beyond that. See the bottom edge in the picture.
https://www.cnczone.com/forums/attac...d=414448&stc=1
F360 is insisting on starting the tool at the top edge! If I select the body for the stock profile it still wants to start the tool in the stock above the semi-circular cutout, which will not be cut until the stock is flipped over. Setting an entry point on the bottom edge doesn't help either. Here is the toolpath I'm getting:
https://www.cnczone.com/forums/attac...d=414450&stc=1 or https://www.cnczone.com/forums/attac...d=414452&stc=1
How can I tell F360 to come in from the edge of the stock that forms the narrow part of the pocket?
Regards, David.
