1 Attachment(s)
What might be the reason of this CNC milling Failure
We heard a sound, that see this defect on our part. The working tool is 5 carbide inserts, Ø50mm side cutter (Face mill)
depth of cut:2mm
Feed is variable arround 400mm/min-2000mm/min
Spindle Speed = 4200 rev/min
I run the same nc code yesterday and everything was fine.
I wonder the reason of this failure on this image attached to the post.
Chip stuck, unstable stock or bad machine
.The code continued a bit after this failure just fine.
Re: What might be the reason of this CNC milling Failure
Quote:
Originally Posted by
Arin93
depth of cut:2mm
Show a photo of the cutter it looks like a insert came loose
I understand.
The material is Cu-ETP (very small amount of other contents, can be consider as pure copper) The depth of cut ap was 2mm : With stepover of %12 (ae=50mm*0.12=6mm)
Operator is still young,he has almost 9 years of experience but in a limited range ( mostly holes and breaking chamfers on 6-15mm materials.) I am in my first year.We are still improving.
We don't have large range of cutting tool in our closet, looking forward to get a decent stack.
So thank you very much for the explanation. I think I understood. :)
