1 Attachment(s)
Wood Routing Machine Price Woodworking Machine Automatic Cnc Router
#atccncrouter
https://www.cnczone.com/forums/attac...d=454646&stc=1
Working Area |
1300x2500x200mm |
Spindle |
ATC 9.6KW Italy original HSD spindle, ES951 Model. 6000-24000RPM |
Control system |
Taiwan SYNTEC 60WE control system with MPG handle wheel, more precision |
Drive system |
Japan YASKAWA 850W servo motor and drivers, Z axis with brand brake.
Japan Shimpo reducer. |
Inverter |
Taiwan Delta B Model 11.0KW |
Machine Frame |
New type thicker and bigger heavy duty 8 mm |
Working table |
Vacuum table with T slot, 4 Zones |
Tool Magazine |
12 pieces with Carousel Tools Changer |
Guide rail |
Taiwan PMI linear guide, 25# |
Transmission |
X,Y-helical rack pinion, Z axis with 2505 TBI ball screw |
Tool sensor |
Automatic tool sensor |
Collect |
ISO30 tool holders with ER32 collect |
Lubrication system |
Automatic lubrication system for rails |
Traveling speed |
65m/min |
Working speed |
25m/min |
Voltage |
380V,3phase, 50HZ |
Limited switch |
Japan Omron limited switch |
Electric part |
French SCHNERDER switch |
Electric Wires |
High soft shield with copper wire to protect against static electricity, UL/CE standard Shanghai Cardiff brand |
Vacuum Pump |
German KVT3.140 4.0KW Becker vacuum pump |
Dust Collector |
1.5kw double bags dust collector system. Europe CE standard |
Drilling Head |
Italy HSD 9 vertical type |
