How to improve the marking depth of the laser marking machine?
Many manufacturers who use laser marking machines to process various products have experienced the development of primary business to stable and sustainable development. However, in order to further improve the technology, the requirements for existing laser marking machines have become higher. For example, it is necessary to increase the marking depth of the laser marking machine. Here are some suggestions on this issue.
First, optimize the interior of the laser cavity, replace the light guide medium or pump source to improve the beam quality. Because the laser beam is reflected and focused by the lens, this accessory can also be replaced with a better laser mirror. It is worth noting here that when the modification is required, the internal structure configuration and operation principle of the laser marking machine must have a certain professional level. If it is not a professional, technical support can be provided by the laser equipment manufacturer.
Second, another major factor affecting the marking depth is the power of the laser. As the core of the laser marking machine, its power is improved and the working efficiency is improved. However, this is a way to increase the input cost, as long as Economic conditions allow.
Third,replace the lens, the focus focal length is shortened, the beam becomes more concentrated, and the laser intensity can be improved. The laser spot effect of the corresponding laser marking machine will also be significantly improved.
