Electro craft E723 documentation and driver, how to run?
Hi
I want to run servomotor. Just some forward and reverese movements.
Electro-craft E723 0723 32 018.
I can't find any specifiaction
What are the parameters?
What driver to use?
Maybe easier will be to install some new motor, but I don't know main parameters - torque, speed.
Regards
Re: Electro craft E723 documentation and driver, how to run?
What I have is 25.4 lb/in Stall torque, Pk torque 125lb/in, max term voltage 107vdc, 3000rpm max, some have a tach, which is not used in current systems.
Thank you.
What popular driver can I use for mentioned motor?
Regards
What do you intend to control the motor with, Manually? or with some kind of simple program?
There is the A-M-C and similar servo controllers that can move the motor with an analogue signal or a pot etc.
Hi
I need some manual control. Forward, backward, speed control by the potentiometer or simple analog signal.
Regards
As mentioned, I usually pick up a DC servo drive, A-M-C etc drive off ebay
I'm don't know which one can be proper for this motor.
