Fanuc 16i-MB on Robodrill - a couple of issues!
Hi All,
I've recently acquired a Robodrill with a Fanuc 16i-MB controller and have already hit some problems. I have tried searching the forum, but can't quite find what I need or answers were sent via PM so I can't see the resolutions.
Problem 1:
Helical interpolation - I get the "Alarm 021 - illegal plane axis command" despite the format of the G2/G3 movement looking correct and G17 active. I see talk of this being either a missing option or just a parameter change and need to work out which is the case for me. All threads I could find on this ended in a secret pm!? :(
Problem 2:
Jerky movement is 3D surface machining - I need to use High Speed Machining (G05 I believe?), but the controller does not recognise it? Does this mean I don't have this option or just another parameter? How can I find out?
Any help would be very much appreciated! :)
Best Regards
Aussie CNC
Re: Fanuc 16i-MB on Robodrill - a couple of issues!
Hi fordav11 you can help me ?
I have same problem abot High Speed G5.1. I use Robodrill with a Fanuc 16i-MB controller.
Cam 3d does some F cut to F8, I set it to F1000.
Most of the time that f decreases in the arc.
What parts of the parameters can I modify?
I am using Robodrill T14ia control 16ima.
Thanks.
picture https://ibb.co/nc3SLHK
