[TNGv2] - Files and folders
Basically TNGv2 is just three files. An executable and two libraries. This doesn't mean that no other files are created later.
Setup will install these three files and subfolders:
Doc - here are user manuals
Lang - here are localization files for other languages
Samples - here are sample g-code files
Profiles - this folder contains profile folders which contain all your settings/scripts/configurations,...
Profiles folder is an interesting one. Upon first application start new empty profile named <Default> will be created with two files:
Settings.settings - this is main settings file
Keys.txt - this file contains keyboard shortcuts definitions
Other files used by software are also stored here. Most common are:
License.lic - this is license file
Parameters.txt - this files contains persistent parameters. Persistent parameters keep their value between restarts.
ToolTable.txt - this is tool table file. It contains information about your tools.
CoordinateSystem.txt - this is coordinate systems table file. It contains information about your coordinate systems.
Custom toolbar buttons are defined in files named:
BtnTop.txt
BtnBottom.txt
BtnLeft.txt
BtnRight.txt
Custom 'State' tabs are defined in files named:
State<num>_name.txt
Configuration for USB extension modules are in file:
Usb.txt
Expression evaluator configuration is in file:
Expr.txt
There are also some folders in your profile folder:
Scripts - here are all scripts that override default software behavior
UserCmd - here are your custom commands written as g-code or python script
UserGen - here are your g-code generators written as g-code or python script
Each of these additional features deserve its own explanation and tutorial which we will create.
