spindle polestred setting problem
Dear All
i have facing some problem in my machine that is DECKEL MAHO i wrote my problem below please if any know the any fruit full solution so please let me know.
Tool clamp unclamp is not work properly
Check Clamp unclamp switch
Switch is ok
Check Air Pressure
Air Pressure is Ok
Check the setting value is the distance from the spindle nose to the face of the holder
Polestard setting is 109mm
Polestard Setting Procedure
1) Tubular retaining tool
2) Socket screw key
Press the manual mode
Release Unclamp switch
Tubular retaining and socket screw engage
Tubular retaining tool move to left side
Check polestard size 101.1mm
Tubular retaining tool move to right side
Polestard setting is not lock properly
But tool Clamp unclamp is ok
During process the polestard setting disturbed due to which harbor got unclamped and accident happened the polestard setting reading before 103.5 and the reading
after accident is 96.2
