3 Attachment(s)
Entry/Exit cutting collision auto avoidance
For a part with small holes, or the part space is small than the extry length, there is the possibility of cutting interference, because the default extry/exit (lead in/out) type is set for normal size part and holes. CutLeader would auto detection the problem now.
Attachment 418384
User don't need to correct them one by one, thanks for the "Perform Interference Check" option in sequence page, CutLeader would auto detect and correct the entry/exit when running the Auto Sequence command. The interference would be avoided by adjusting the position or shorten the length of lead in/out.
Attachment 418386
Here is the result after adding sequence.
Attachment 418388
