2 Attachment(s)
Help with how to wire touch plate to a CNCEST 3040T CNC router with parallel port
I have a CNCEST brand 3040T CNC router using Mach 3. It uses a parallel port interface. I'd like to incorporate a Z Axis Zero Touch Plate. Its a 4 axis model so the additional socket in the second picture is used for the 4th axis. Does anyone have one of these that has connected a touch plate? How did you do it? Th efirst picture shows the guts inside the control box. Power supply is off to the left.
Thanks for the help.
Chris
https://www.cnczone.com/forums/attac...d=453386&stc=1 https://www.cnczone.com/forums/attac...d=453388&stc=1
Re: Help with how to wire touch plate to a CNCEST 3040T CNC router with parallel port
Do you have any documentation for the control box?
If not, ask seller to send it to you.
No documentation. I'll try to get in touch with them.
No luck getting hold of CNCEST. What a waist of time. Does anyone have a manual, or scan of one for this beast?
Thanks.
Chris
1 Attachment(s)
Quote:
Originally Posted by
cvuxton
Thanks.
Chris
I have a 3040t but no 4th axis pm me with email I will scan mine and send it. Warning it is useless and unless u can understand Chinenglish it is very hard to make heads or tales of it ...you are gonna need to take some pics of the bob( breakout board ) does it look kind of like this Attachment 456720
