Re: Outboard: 0-10v output
Output board is galvanically isolated. You don't need anything.
OK thanks. I look for the electrical problem elsewhere then.
Power supply for Output board? If it is not transformer based then it is not galvanically isolated.
It is a 12V 5A switching power supply, I think of Chinese origin that also powers MK3-4, could this be the problem?
Quote:
Originally Posted by
mar_cone
What controller are you using?
I've got a cheapo parallel port bob running my mill that takes a 12-24v psu into the spindle control part. I don't use spindle part as yet but my manual states that it may not reach the full 10v output if used with only a 12v supply.
Grazie per il tuo commento dazp1976 ma questo non dovrebbe essere un problema in quanto il controller di velocità del tornio impiega 7 volt per raggiungere la velocità massima.
PS: I typed wrong ... the power supply is 12 Volt
You can not use same power supply for controller and for output board. There is no isolation in this case. Even if you use separate power supply but it is switching type isolation is not implied. Only transformer power supplies have true galvanic isolation.
Ok, so two transformer power supplies. One for MK3 and one for Output Board ... I must also use a larger electrical panel
I do it right away. For the stepper motor drivers can I use a switching or do I have to change the one with a transformer too?
If controller uses USB connection then it is "grounded" through computer. Transformer for controller will not isolate controller.
You're right, USB also grounded! At this point I have to understand if it is appropriate to replace the lathe controller with one that has the 0-10V input isolated and not to touch the electrical panel of MK3
Output board is isolated if you use transformer.
Comincio a essere confuso :confused:... ora provo a cambiare l'alimentatore della scheda di uscita e vedere come va.
per il momento grazie per l'info.
You wrote that you will also change PS for controller. I wrote that there is no point because of USB cable.
But Output board is isolated from controller! You only need to power it with transformer to get isolated 0-10V.
Sì, in effetti, come ho detto, ero confuso. Ho aggiunto un alimentatore per trasformatore solo per la scheda di output e tutto funziona ora:banana:
Ma ho bisogno di un altro suggerimento, con un divisore resistivo, posso limitare l'uscita di tensione minima e massima dalla scheda di uscita? Sfortunatamente, regolando la tensione di uscita dalla scheda di uscita per la massima velocità (1250 RPM) impostando la velocità minima (150 RPM) da TNG, il mandrino si spegne, viceversa se aggiusto la tensione per la velocità minima impostando la velocità massima in TNG sembra che il tornio decolla (supera i 2000 giri / min).
mar_cone
I answer myself ... as often happens, the solution is found by reading the manual. Fixed by changing Minimum and Maximum Frequency in the spindle settings
