Help me analyze this stepper circuit - Boss machines
Ok I hate to beat this issue to death, but I want to figure out why transistor failure is so common with the Bridgeport boss machines. Their has to be some major flaw in the circuit design. You almost never hear about it in any other machine.
Here is the circuit:
http://i264.photobucket.com/albums/i...027773crop.jpg
If I understand back emf correctly, the voltage will be opposite of the applied voltage. So while the coil is active, if the voltage at line 31 is 60v, and 0v at X1, then when the transistor is shut off for the leftmost coil, the voltage at X1 will be more positive than 31, say 120v. It appears to me that their is no protection for this. The diodes D33 and D29 would only be effective if the voltage at X1 were less than ground (line 39). Is this a flaw in their logic?
Most diagrams I could find on the net show a diode across the motor from what is normally the negative side to the positive. This would make sense as it would keep the voltage that the transistor would see at the collector capped at 60v. I modified the above diagram to reflect this:
http://i264.photobucket.com/albums/i..._resistors.jpg
But, wouldn't these diodes be a dead short across the coils when freewheeling? Effectively braking the motor? And probably frying the diodes? I added resistors inline with the diodes on the following diagram, but I have yet to find a stepper driver diagram with these.
Can someone tell me if I am in the wrong? I am having a hard time finding information on exactly what goes on with voltages during back emf.
This also assumes that the transistors are dying because of too high voltage across collector to emitter, and not base to emitter. I need to look at the SMD board to see what kind of voltage the base could be seeing.
Thanks!
Joe
2 Attachment(s)
Next 1 is an image of the aspects.
I can drive uni-Paula stepping by two circuits.
I hope to replace the inside of the dotted line with MPU.
There are three modes.
One red -NchFET-ON, electric current is early and increases.
Two magenta -F Di,PchFET-ON, electric currents decrease slowly.
Three blue -b Di-ON, electric currents are early and decrease.
The connection diagram does not consider dead time.
When there is a drive signal of SW1; one mode.
A case beyond the analog voltage, two modes.
When there is not a signal of SW1 and SW2; three modes.
The web page is Japanese.
I added some circuit simulation.
http://den-nekonoko.blog.so-net.ne.jp/2009-04-19
