Re: Simple Workshift OSP700
I would use Variable as counters and adding -3mm to your work offset every time, remember to put some IF commands in there so it stops when you reach 20 parts.
Have fun Masterblaster
hy jimmy, if you wish 2 make it work by using vzshz, you have to change from sdf & min to min & ssb, because sdf is doing some stuff after each cycle, including reseting the vzshz ( because program is re-loaded )
if you wish to keep the sdf&min, you could use a common variable, in order to shift the origin, but this seems pointless, because sdf is using Q, and, because you can't read the Q value, you have to read the common variable, so sdf seems useless ... again, one more for the min & ssb combo
also, using sdf leads to downtime ( but this is it when there is limited memory )
if you wish to keep the sdf&min, and have a nice code, then replace vzshz with vzofz ( i don't know if this works for your osp )
in the end, whatever you do, you should reset the master counter ( eq reset the common variable, by para\edit, or by using a presetter program )
more tricks here ( at point 2 is a code that auto-resets the counter, located inside main program ) : https://www.cnczone.com/forums/okuma/369696-cnc.html
kindly :)
ps : use M02 inside *.min, and END inside *.sdf
Thanks for the help guys, looks like I need to do some more reading in the book.
Might go with the .min & .ssb option jeez they make this difficult. So easy on a Fanuc haha!
I'll keep you posted....
NOEX VZOFZ = 100
CALL OSUB Q20
M02
OSUB
// content
NOEX VZOFZ = VZOFZ - 1 ( change origin before rts )
RTS
... avoid mid-program reset / kindly :)
OK so looks like I have had some success, went with the .min and .ssb option
Called my sub prog OSUB.SSB and put OSUB as a header and RTS at the end
MAIN.MIN
N100 V1=0
N200 CALL OSUB
N300 V1=V1+1
N400 G91
N500 G50Z3.25
N600 G90
N700 IF[V1 LE 20]GOTO N200
N800 M02
Now to run 2000 of these rings haha!
Code:
V1 = 0
N200 CALL OSUB V1 = V1 + 1
G91
G50 Z3.25
G90
IF [ V1 LE 20 ] N200
M02
( . . or next shorter code . . . . . . . . . . . . . . . )
CALL OSUB Q20
M02
OSUB
// next line should be before rts
VZSHZ = VZSHZ - 3.25
RTS
so, you open the chuck only once / 20 parts ? don't you have overhang problems, are those really thin ? just asking / kindly :)
ps : you can have the osub content inside the min file, thus is not critical to have the osub inside a separate *.ssb file; if program is simple ( small or few soubroutines ) then i put them all inside the min, otherwise, for more complex parts i use several ssb's, one for each operation, in order to achieve modularity
Yep its a piece of seamless stainless steel tube, making decorative rings 1.5mm thick using a 1mm part off tool.
It's been running perfectly, thanks again for the help
