Re: Z zero reset - gcode?
Are you using your own script? Some kind and awesome gentleman posted an add on for setting zeros in one of the forums here. X, Y, and Z. It's great. No need to write your own. If that's the one you're using, I can assure you that the fault is not with the program he wrote, because that thing works awesome for me.
As for camworks, I have no idea. But if you want input from someone, a screenshot of the code is probably the best way to achieve that goal.
Quote:
Originally Posted by
NIC 77
I think this issue is around camworks-> Mach3
its doing some crazy stuff that is not making much sense, i am guessing camworks is putting some smarts into the g-code which between Mach3 and the sherline its not working (SIGH)
Look for G43 in the code, Tool Length Offset.
