Feed Rates - Over The Speed Limit
Hi All,
I'm just getting comfortable running Mach3 with my new CRP 4x4 Machine. In general things are working well. I've had some good and repeatable experiences cutting quite a few 2D parts. So at this point I thought I'd try some 3D carving.
Here's where my question comes up. When I cut 2D tool paths at 160 in/min., I see the feeds rise up to 160 in long straight-a-ways like they should. Now when I run a 3D tool path at 160 feed rate, the long straight cuts can climb as high as 600 in/min.!!!
I've checked the G-Code. The line before these fast cuts says, F160.0. Yet it will climb to my rapid setting of 600.
I'm thinking it MUST be something with Mach3 settings. I also posted this over in the dedicated Mach3 forum as well.
Any help would be appreciated.
-- Bernie
