2 Attachment(s)
3015 stone processing machine
Attachment 443012
Attachment 443014
This machine can meet the processing requirements of cutting, edging, polishing and engraving of different materials.
The machine automatically changes the tool during the whole process without manual intervention, which reduces the labor cost and improves the production efficiency for the enterprise.
The bed is welded seamlessly with thick-walled steel pipes to ensure higher machining accuracy.
The working table is made of steel plate, which has the advantages of anti-rust, good load bearing performance and long service life.
Re: 3015 stone processing machine
A plasma polishing machine is way more effective. And takes way less space. Of course, it's a bit more expensive, but it's generally considered a better solution and more and more industries are buying it. In addition, it has other advantages you can check here plasma polishing stainless steel https://pvdcoaters.com/product/category/epp
